A Fumoto Valve oil change....using valve, not drain plug
Kalex
California
Again, I haven't installed(used) mine yet, but my SX came with a plastic white barbed nipple extension. It also came with the blue safety clip and two dust caps. Even without the extension I wouldn't be too worried about the hose leaking as the only pressure it will be under when the oil is draining is gravity. I bought it off of ebay for 33.24 including shipping.
KCRaptor643
Tacoma, WA
What's the plug size on 2019 models? Is it M12 or M14, I noticed Fumoto unit says 12mm but some sites indicate being 14mm. I am thinking about the Stahlbus unit, anyone with Stahlbus experience over Fumoto design???
Raptor916
Do you think the 107N might be better because of less parts to fail? If we put a tube on the nipple either way would it matter much to be able to adjust the angle on the 107SX?
