A/C not cooling
Bozz
Royal Smart A$$
Nashville, TN
You can put too much freon in with the DIY cans and it will not work just as much as not having enough. There's a very narrow window of tolerance. If you put too much you may have to bleed some out. Been there, done that. Then mine was blowing ice cubes when I got it in the zone of tolerance.
New recaros
Colorado
A/C issues on my 23 with only 2K miles. Took my Raptor in for the a/c issue and everything checked out according to the dealership. It’s intermittent. Initially woks well but once in a while the fan speed is on max and it feels like hardly any air comes out and it’s not cold, slightly chilled. Once I turn the a/c off for at least 15 minutes and start back up it works fine.
My 19 had an odd problem like this. The damper door was sticking. If it does it again, see if air is blowing out the heater and defrost vents. Can’t remember what they did, but I think they just cycled it 10-20 times thinking dirt was causing the issue
sheaks3
Mine is doing the same thing. Anyone know what the fix is so I can tell true dealer?
sheaks3
Cabin filter is the issue 99% of the time and they’re cheap. Start there, I change mine 2x a year and no issues on a 17.
Thanks for the reply. I have only had it a few months. Clogged cabin air filter should not be an issue.
1BAD454SSv2
HELL I ZONA
Doing good here on way home from work. 115 ambient 43 out vent. See if I can get back to 91 octane holding at 90 now. Running 87 stage 2 cobb ots map in this miserable heat.
1BAD454SSv2
HELL I ZONA
Yes still 91 it's adding more timing than it's pulling. Don't plan on breaking any speed records next few months. Real doggy with tune and density altitude at 4000ft.
1BAD454SSv2
HELL I ZONA
A/C Still doing great . Also inferred octane up to 91 now. I will stay on 87 tune.
