6.2 sparkplugs ?
Huck
Chicago Sw Burbs
Drives side back ones were w bitch, steering column gets in the way. But it's doable with a lot of m*^%^ f$%^%
Yukon Joe
Trafford, PA
Just got a quote from the dealer. $450 to replace all 16 + $165 for a fuel injector cleaner.
So @Huck what tools did you need to get at those ones around the steering linkage?
Thank You for your donations to Avery. We hit our goal!
Yukon Joe
Snoball 3
Delta Lead
www.runraptorrun.com
Yukon Joe
Trafford, PA
Small hands (no jokes ******) and a full ratchet set worked for me.
Why did you go with the ngk-6510? According to the part look up on summit racing the ngk-6509 is for the Ford Raptor. Only difference I can see between the two part numbers is the heat range number.
Ngk-6510 is a 7
Ngk-6509 is a 8
I can't access the chart here at work, so not sure which is the better? Look to both be the same price.
Yukon Joe
Snoball 3
Delta Lead
Hazzard
Southwest MI
I don't recall why I choose the 6510, I think read somewhere that the one range cooler were better for what mods I had at the time. I think either JDM or Livernois recommended them also. I also have used NGK pretty religiously on my quads and sleds over the years. A lot of it depends on what tuner your running also, 5* I think recommends Motorcraft.
Yukon Joe
Trafford, PA
The motorcraft part no. SP-526 are about half the cost at $4.49. Lol...
I believe the 7 means it runs in a cooler range than the 8. Not really sure though.
Yukon Joe
Snoball 3
Delta Lead
Hazzard
Southwest MI
Ya the cheapest I found the ngk's were around $7.75-8.50. The one range cooler I know makes a difference depending on how you modded the engine and how aggressive of a tune you run.
Yukon Joe
Trafford, PA
So for the long tube headers and constant performance tune I should also get the NGK-6510. Cooler = better.
Thanks for the help.
Yukon Joe
Snoball 3
Delta Lead
