6.2 sparkplugs ?
Hedges4
Law Enforcement-Fire
Central IL
Anyone know if there's an estimate of how many hours it will take a technician to change all 16 sparkplugs on a Raptor?
Thanks!
Had mine done with the turbo, took about and hour and half for just the plugs.
40oz
Sorry for the double post, found this more recent spark plug thread.
What is the trick to getting the two plugs behind the shock mount? 1 on the driver and one on the pass? I could not get my hands in there and start the plug socket.
biturbomg
Non Supercharged 50K is a good idea. Ford says 100K...
Supercharged I would do 20-25K
JimIII
Jim what plugs/gap and cost for all 16 and is 3hrs normal time for install for a tech or can it be done in drive way in that time.
Thanks
JimIII@JDM
New Jersey
Camperguy
Masshole
Curious why no one is running the Denso Iridium TT PT#ITV20TT 4719 .I have run them in everything . A very nice salesman at AutoZone gave me them at cost for Veterans day! Usually $7.99 Ea. The longest I have run any plug is 30k and these plugs maintained factory set gap with no show of wear. Thats why I went to them.
Bill
EricM
OHIO
I prefer NGK. Any of the fine wire iridium plugs are good though.
Camperguy
Masshole
It typically takes us almost 3 hrs to change the plugs on a Roush SC truck. It's a little technical but could be done in your driveway, it does not need a lift or anything. We use the NGK 6510 plugs and gap them to .030"
NGK-6510 Spark Plug 6510 For the Ford Raptor Truck 6.2L - JDM Engineering
Is the .030 gap to prevent flame blowout? I was curious if the coils on the Raptor work like the standard DIS coils , where one fires center electrode to ground and the other ground electrode to center?
Would a voltage stabilizer using capacitance/reactance to reduce voltage noise and fluctuation?
Thanks Bill
