Squatting Dog
please take a picture of said valve![]()
I will do that right now... Crappy cell phone pictures incomming..
-Greg
Okay here it is..
New canister purge valve
Old canister purge valve.. It is located behind throttle body and held in with to 5/16 bolts. There is a wire connector and a white vacuum line clip.. You have to squeeze tabs on bottom and pull white clip up to free valve.
Old purge valve, full of carbon and crap.
New one installed in about 10 minutes.. No more weird idle or ticking (cheap relatively speaking $55 from Ford)
-Greg
The timing chain assembly has a hydraulic tensioner. Effectively, it's vaguely similar to a hydraulic lifter.
Sometime it takes a few seconds to 'pump up' and can cause a 'knocking' like sound.
Injector ticking is a very soft "high" clitter at a rapid pace. Not so much an actual knock.
The tensioner noise most closely resembles upper valvetrain noise or piston slap.
Old/high mileage oil, excessively heavy/thick oil, and/or an older or malfunctioning oil filter that was previously mentioned can all factor in as well.
