Nesc204
- Joined
- Mar 26, 2018
- Posts
- 415
- Reaction score
- 466
The old saying is TRUE. THERE IS NO REPLACEMENT FOR DISPLACEMENT.
The dry sump is for cornering. The corvettes or any sports car is going to have a similar system so the motor doesn’t grenade going through the turn. The camshafts probably shifted the power band to the upper limits compared to the Raptor where the power comes on at lower rpm range (truck).If you guys think your gonna get these numbers on HO 3.5L your nuts.
The GT employs a four-stage external dry sump oil pump and has an oil capacity of 15.3 US quarts (14.5 L).
That's just one thing you are going to have to do to keep the motor from blowing up.
Then after you spend another $30K with aftermarket upgrades (which doesn't exist) you may have something.
There is a big difference in V8 sounds... (seems to be the #1 reason people prefer a V8).
Dodge and Chevy trucks (even older Fords) pull up near me with loud exhaust systems and it sounds like crap... like a boat.
It needs to be a crisp, raspy snappiness to the note... not a bloaty, wafting, ogre sound.
Good point Norcal SaSquatchOr farting sounds. You left that one out.
Did they release the 7.3 weight? Someone mentioned 100lbs more... sounds like a light estimate.
