40" light bar behind grille?
Mariner
Lakeland, FL
For real? I looked at HD and did see anything similar to what Rigid sells. IE open in the middle. Got a link to something that will work?
The mounts I have won't work so I have to get the rigid ones or buy something else.
Amazon sells them, and I believe some of the venders here do too. If you want a fail safe, just spend the $40 bucks
Sent from my SAMSUNG-SM-G900A using Tapatalk
d.p
d.p
I already did last night lol. Was just curious if HD really had something that would work.
Mariner
Lakeland, FL
Oh I gotcha. Yeah I have no idea about HD, but Amazon never fails. Do you have the Rigid 40" bar?
Mariner
Lakeland, FL
Very nice. So at least the harness will match if you choose to use it. I bought a cheapie off Amazon so I chopped up the harness and just used the wires because of the nice rubber insulation it comes with
d.p
d.p
Ok so another problem. I got the grille mount kit from rigid but the male connector on my light bar does not fit into either female connector. Do I just need to force it in there? I could always cut the retaining clip on the female end or just cut of f the connectors completely
d.p
d.p
How much and how soon? I already spent $65 rigid connectors that don't work. Can I just cut the connectors off and hardwire it?
Dane
Littleton, CO
Yes. They're just wires. Cut and splice together or use whatever connector you like.
Just throw butt connectors and some heat shrink on there if you like. Do you really expect to disconnect it often?
d.p
d.p
Haha no man but plug and play is a good thing you know?
