Wilson
so what tires are on a stock raptor and rims so I know people ask me all the time I just say who the hell cares or look I didn't buy the truck for the tires. I wear boot's
I started a thread about tire Clearance at full compression here;
http://www.fordraptorforum.com/showthread.php?t=15219
In rock crawling, we frequently ran 1" body lifts for an extra bit of clearance. These were often high quality aluminum pucks, not the typical injection molded stuff.
Anyhow, based on my experience detailed in the thread above, I think a 1" body lift could be the hot ticket for clearing aggressive 35's or 37's when the tires get completely stuffed. It would probably be easier and cheaper than modifying the wheel wells for clearance.
If you are running solid body mounts, yes you would have more nhv transmitted to the cab. However, unless you are caged and tied into the frame, you do not need solid mounts. The 1" aluminum pucks we used are stacked on the stock body bushings, so the stock body isolation is retained.
If you like it that's all that matters
