37" BFG ATs
Hoverp
Central Montana
I had previously trimmed when I had my other Projects on temporarily and those still rubbed.
So far with the very minor trimming, the all terrains haven't hit once.
Here are a couple pics showing what little trimming I did and the clearance with the all terrains:
Edit... Wheel is turned to position the tire at its closest point of potential contact. When the tires are straight, there is a ton of room.
Where and what exactly did you trim?
Thanks
Raptizzle
FYT
Southern CA
Thanks
The last couple inches of the fender flare at the bottom. So that way if the tire made contact, it wouldn't rip the flare off.
Looking back at the post you quoted of mine, I should ad that since the truck has now settled, the tires are rubbing when compressed on turns.
FP Forged
Justin
Reno, NV
Bit the bullet and went 37x12.5x17 mt km2. Should have them next week.
I knew I should have posted the set I have in the classifieds. I have a set I'm trying to get rid of for $1000. Post some pics when you get them on.
Phyguy
Denver, CO
Noob question on sensors: Do I need a sensor in every tire (including my two spares)? Or, just the four main tires? Wondering how many sensors can be bound to the controller per wheel...and how the controller knows the wheels are spinning other than some sort of interaction with the wheel position sensor.
Anyone have a good recommendation on sensors? And a programmer?
Thanks!
Matt
LekRap
Corona, CA
Does anyone know where I can buy a set of 37x12.5x17 bfg at's?
New? Try discount tire/America Tire. They seems to have decent prices, just got a quote the other day. They have the old style (KO's) in stock and the (KO2's) should be coming in March. I was quoted around $320 for either ones in 37/12.50/17. They are good because you can work them down a little too.
If your looking for used, someone on here might sell you some. Could try opening a new thread on the want to buy section on here and look at the garage sale section.
Good Luck
FP Forged
Justin
Reno, NV
The Tire Rack has a few sets left. 2 sets in DE and 1 set in LA
Or if you can find a tire store that buys from American Tire Distributors they have over 100
6point2
Oklahoma
I usually get my tires from discounttiredirect. I called them but they are out of stock. I'll check the actual discont tire store and tire rack tho.
