37" BFG ATs
JDUB
Wildomar, CA
Noob question on sensors: Do I need a sensor in every tire (including my two spares)? Or, just the four main tires? Wondering how many sensors can be bound to the controller per wheel...and how the controller knows the wheels are spinning other than some sort of interaction with the wheel position sensor.
Anyone have a good recommendation on sensors? And a programmer?
Thanks!
Matt
My spare did not have a sensor. So maybe the controller only looks for 4 sensors...
Madcowranch
Genetically Modified
OK
I usually get my tires from discounttiredirect. I called them but they are out of stock. I'll check the actual discont tire store and tire rack tho.
Are you near a Sam's Club? That's where I got mine last Fall.
6point2
Oklahoma
I found a set and I'm about to pull the trigger. Question to anyone who runs these or has seen these on a raptor. Do they look too narrow?
ModFreaksRAPTOR
Fort Leavenworth, KS
Too narrow? 37 x 12.50 x 17 BFG AT? I'm running the 37 x 12.50 x 17 KR2 and they are anything but narrow man. Maybe they look a bit wider than the AT KOs but I would think they would be the same if both are 12.50.
MF RAPTOR
Truckzor
Found these pictures, this truck is on mid perch and BFG 37's.
Question... that's a stock BFG on mid-perch with a 37x12.5r17 BFG KO2 next to it?
If so, that's a big difference! Even with the stock tire having ~ 1500 pounds on it.
Savannah, GA
I want to thank all of you who posted to this and other threads. I have read through pages and pages...and I appreciate all of the knowledge out there. I have already called to get my '13 OEM wheels powdercoated ($60 each) and will get a set of 37" KO2s on them when they are done. I will post the outcome...MTF.
SuperRaptor
Seattle
Aren't the KO2's a bit larger?
