2nd Application of Adams Ceramic Spray Wax
AFPhysO
Colorado
I’ve got the ceramic spray on the Raptor and the graphene coating on my wife’s Yukon. They’ve been on close to 2 months I think. Washed the trucks the other day and both were spotless in no time. All the grime just wiped right off and after hand drying and a little of Adams CS3, they looked like I had just waxed them. Bet I spent 90 minutes combined on all that.
You can’t go wrong with either version of Adams ceramics. The spray is super easy but the coating supposed to last for years.
AdamsPolishes
I put Graphene Ceramic Spray Coating on my truck today. I didn't use surface prep but I did clay mitt the truck and dry using detail spray. I'm hoping I still achieved a solid bond of ceramic coating.
Adam's - did I just waste my time or will I get some good results from applying the ceramic spray even though I used detail spray to clay then dry? Also, I noticed it didn't rainbow on my wheels... is that normal?
Unfortunately, the Graphene Ceramic Spray Coating will not last as long when applied over the Detail Spray. To get the most longevity out of any ceramic, it needs to bond to bare, clean paint. Next time, use the Surface Prep to remove the clay residue and the wax in the Detail Spray.
Tim Tullio
Germantown, Ohio
Used Adam's Surface Prep on my wifes Lexus yesterday followed by their Graphine Spray. Looks pretty nice. I used a clay pad (not bar) on it ahead of time. Only thing I noticed was the clay pad (which is synthetic) does not make the surface as smooth as a clay bar. I have an identical Lexus I used a clay bar on over a year ago and my wife's Lexus isn't as smooth as my clay bar'd Lexus parked next to it. The clay pads are easy to use though and I could see using them as maintenance after a proper clay baring.
bviperd
Long Beach, CA
AdamsPolishes
Should I add a second coat after my next wash? What should my plan of action be to do next?
Adding a second application will not really help, as the issue is the lack of the first coat properly bonding to the paint. A plan of action would be to wait until the current application is worn off, by monitoring the beading action, and then prep the paint using Surface Prep and apply the Graphene Ceramic Spray Coating.
bviperd
Long Beach, CA
Excellent! Thank you! I only use your products. They are great. I appreciate the support and info as well!
C
Cory84
North Dakota
It looks like my original CSC is still in pretty good shape, so I took a clay bar to a small area and it cleaned the roughness up easily. Is there any harm to the coating by using a clay bar?
AdamsPolishes
The clay bar will not remove the coating, but claying does have the potential to cause marring on the surface of the coating. Just don't be too aggressive with the claying, and use lots of Detail Spray for lubrication. I prefer to use the Clay Mitt on a coating, as it can be rinsed out often to help avoid any surface marring.
policedutchdog
California
I just detailed my tuck over the weekend using the Graphene Ceramic Spray. I washed the truck then clay bar using the detail spray while it was still wet. I then did 2 coats of the Ceramic spray letting it cure for 4 hours in between coats. Came out just as good if not better than my wifes Lexus that I used CQuartz ceramic coating on.
