shapiroeric
How many miles on yours and build date?
4,000 and don't know the build date
Guess they had two years to work on an aluminum bed or is the raptor bed any different in the way it was constructed in comparison? Not sure on the cab.
If anyone knows how to break a bed, I've done it.
Build date is right there when you open up the driver door
Just give it time. This is a completely new truck for Ford and everyone knows that there always tends to be glitches and issues with the first year, hence why some buyers stay away until things get worked out. Ford is learning.
I personally am waiting until 2019 before I consider letting go of my GEN1 and start looking at a GEN2.
Mine goes in Wednesday. The tech said there are many notes in the system. Several say they replaced the pan and they still leaked. He said its suggested to replace the PLASTIC oil pan then let the seal cure overnight and fill oil the next day. According to him they have had better results with this method. (Yes I put plastic in caps; because I do not agree with plastic oil pans- guess I'm old school)Same oil issue here....needs a new pan and seal....took a week for them to get the parts and goes in Monday for a 2 day fix....
Yes, they told me the same thing. 2 day repair.Common problem with some of these. They replaced my oil pan and seal last week. I guess that some of the composite pans were out of tolerance. Easy fix. They replaced my pan and let it sit overnight. Filled the next morning and brought it back to me with no issues since.
My build was early February. Noticed leak at 2300 miles. Took it to NYC Thursday. Oil level did not drop much at all in the 1200 mile trip. I checked every fuel stop and I was expecting to add oil but did not add any. Mess under truck looked worse than I guess it is.Build date is right there when you open up the driver door
