2020 superduty 10spd - how similar to the raptor 10spd?
EricM
OHIO
The numbers are metric trans rating e.g. Newton Meters - you have to convert to ft/lbs
800 = 590
1400 - 1032
Supposedly. We all know it clearly corresponds to torque capacity, but AFAIK, Ford has never confirmed that those numbers are their actual torque ratings. That's why you got some guys thinking it's ft-lbs, and some N-m. Ford has never said one way or the other that I've seen.
RC Blk Bird
Arizona
Straight from Ford
Ford 10R80/GM 10L80 Transmission Specs
Transmission:
Ford 10R80, General Motors Hydra-Matic 10L80
Type:
10 speed automatic
Production Plant:
Ford 10R80
Ford Livonia Transmission Plant, Livonia, Michigan
GM 10L80
Romulus Powertrain, Romulus, Michigan
Model Years/Applications:
2017 - current, various applications
Case Material:
Aluminum
Max Input Torque:
~ 800 N-m (~590 lb-ft), nominal rating
Weight:
~ 230 lbs
ATF Type/Spec:
Motorcraft ULV ATF (Ford applications), DEXRON ULV ATF (GM applications)
Transmission Fluid Spec (ATF):
~ 13 U.S. qts
Normal ATF Temperature:
206° F to 215° F (96° C to 101° C)
Transmission Filter P/N:
Motorcraft FT-202 (GM p/n not available at time of publishing)
Service Intervals:
150,000 miles (replace transmission fluid and filter)
Features:
• Adaptive strategy perpetually adjusts shifts schedule in anticipation of driver's manners and driving conditions
• 1 piece transmission case with integrated bellhousing
• Variable displacement vane transmission fluid pump
• 260 mm torque converter
• 10 forward speeds, 3 overdrive ratios
• Rear wheel drive applications only
EricM
OHIO
So you copied that "straight from Ford" info from dieselhub.com? You got anything actually from Ford?
Again, not saying it's NOT 800 N-m but, I've yet to ever see anything from Ford directly confirming that over the 20+ years they've used this xrxx convention.
NE Raptor
Massachusetts
Has anyone been able to drive a new superduty with the 10spd? I was curious if it acts similar to the 10spd in the raptor. looking for positive/negative experiences. That seems like a great application with the diesel.
WOW this got off topic. To answer OP - I have not personally but my best friend just scooped a 2020 diesel sport and he said it shifts super smooth and the torque of the truck is insane, this was my first question for him once he drove it. I would imagine I will be driving in the very near future so I will let you know how it goes. I also have no qualms with the 10 speed in the raptor, I think mine shifts super smooth and have not had issues that others have experienced.
Members online
96,139
59,972
23UniFordicorn23
