2020 raptor- Geiser or eibach
TheTeej
Denver, Colorado
I like the eibachs, for the price.. didn't really change the ride from stock but added some ride height in front.
I've never had geiser springs on either gen1 or gen2, but I just can't justify twice the price for the geisers vs eibach.. on paper progressive springs would be better off road and jumping, but my truck is 75% street.
i have eibach fronts, with deaver +3hd and the @RPG billet drop shackles..
How does your truck handle jumping with the eibachs in the front vs the stock spring? How did those deavers ride w/o the chase rack weight?
CenCstRptr
CA
Just curious— what wheel/ tire setup are you running?
Any trouble with rubbing, with the Eibach up front?
downforce137
In Diana
i had the rack and spares before the deavers. It sat a bit lower but everything was fine. did a long trip out west because deavers didnt arrive in time..
i think the eibachs are great, but again, i have no experience with geisers..
method nv's, cheif machining center caps, custom powdercoat, toyo m/t 35x12.5-17
they rub a bit at full compression, but thats not the springs fault. the offset/backspace causes it with the wider track width.. ill get fiberglass someday.
CenCstRptr
CA
they rub a bit at full compression, but thats not the springs fault. the offset/backspace causes it with the wider track width.. ill get fiberglass someday.[/QUOTE]
Yes, the Methods run a 0 offset. With less offset should not have ant rubbing, I would think.
Your experience with this set up- would you ever consider running 37s, or too much involved to get them to fit w/ out considerable rubbing?
downforce137
In Diana
Yes I'd like 37s someday, but again I'd get bigger fenders sorted out first.. I think there's a few other downfalls to 37s, like the weight, but still might do them eventually
sixshooter_45
Arnold
Billet drop shackles, were they stock length?
