2020 B&O System low volume
ArgoGator
Gem of the Hills FL
I've got the same problem on my 2020. Turns out there is a technical bulletin SSM 48346 about the issue due to incorrect configuration of the digital signal processing (DSP) module.
David1986
David1986
Clarksville, TN
I asked my dealer about the possibility of the amp/sub not being turned on or configured correctly and they looked into it and said everything checked out.
After replacing the amp/sub package, it solved my issue.
Hope they get your solved soon!
tom wansor
new york
I found this in my ACM module. Not sure if same issue. IMG_20200416_132727424.jpg
ArgoGator
Gem of the Hills FL
Took it in this morning and gave them the bulletin. That is what is was. Sounds better now.
