David1986
Great. Plenty of volume now?
Yes...sounds Awesome on level 13! It came to life.....
Just replaced my 18 with a 20 and the B&O system's volume seems weak. Have to turn the volume level up to at least +20. Doesn't seem right. Guess I'll take it to the dealer and see what they say.
I also have a 20 base model Fusion and the base stereo in it Rocks. Can't turn in past 16 and it's load. Makes no sense that the B&O system is amplified and the volume seems to be low.
I've played around with the settings and it's helped some.
1. Turned the speed adjustment off
2. Surround sound is turned on
3. Balance is slight to the front
Thoughts?
I thought it only went to 11?[/QUOTE
It goes to like 28-30. 13 is close to half way up.
Yes...it sounded like a base model audio system before they fixed it. Volume I think goes up to 28-30. Had it makes out and it sounded horrible. One of the techs thought it sounded fine. Had them get two trucks side by side and check the volume on both, then they said yep it's messed up.
Set the volume now on 13 and it's cranking!
Lol, David1986, you must be under 40 years old.
