2017 Raptor Geiser Progressive Springs
0-60 freak
Been pounding on mine and like gen1s, think these are exorbitantly better than stock, especially level kits. Rides so nice.
I was hoping they would be taller than the advertised 2" and they are. I'm currently taller than I was on 5th ring of rpg collars (rpg claims 3.5 but I don't think so), I do expect them to settle a smidge.
37" Toyo MT
43.8" front
43.5" rear loaded on +3
Also how did u achieve 43.8 front...is that with the 37's?
Sent from my SM-N950U using Tapatalk
kromealt
43.8 front was the 37 toyo mt and pre-settle, this setup ended up at 43.5 both front/back on my 18 and 19. Another tire will have different measurements
0-60 freak
Makes sense now, finished mine last night fresh measurements were 44.25 ft and 44.75 rear, geisers/icon opt194f0644c4f0768dd010ae5e99ca5048c.jpgd9de4d90980e29db0910d06feef04a78.jpgaf380f13a50c82dd14dc80400eef5452.jpgada8c7032e996557981e24f7fab46066.jpgf64a22d7e2235650787bca0385294e85.jpg
joey185
My 2018 Raptor:
Front - mid fender stock =39.5
Front - Geiser springs =42.5
Front - add 37's =43.5
Rear - mid finder stock =41.5
Rear - Deaver +3 =43
Rear - add 37's = 44.5
2 months after install:
Front - Just over 43
Rear - Just over 43
I know this is months old but couldn’t help notice that your +3’s sag 1 1/2 inches., is that correct?
MOT26
Las Cruces NM
Both the Geiser springs and the +3's settled a bit (as expected). That number is with 250+ pounds in the bed. When I take my Diamondback HD cover with loaded tool box off the truck along with my Pro Eagle 3 ton jack and 2nd 37" spare, the rear goes up about an inch. I have not measure the truck empty, just eyed it. Does this help?
rkwjunior
Massachusettes
The zero offset gives the truck a better looking stance but it Will require a little work to avoid rubbing in full lock.
If you can do without the zero offset and stick with the factory offset you should have no problem with the Geiser springs.
Are you rubbing on the inside of the wheel well, on the inside of the tire?
So what about half the offset, like +17. You think 37s will still rub lock to lock?
Raptor911
Ashburn, VA
Please let us know if you experience any issues. There was a member here that raised his 2019 via collars and had issues with his live shocks.
MOT26
Las Cruces NM
rkwjunior
Look at post #139, I explained it there, I even posted a picture.
If you still have questions I could explain it further.
rkwjunior
Massachusettes
rkwjunior
So with a +17 offset, do you think that rubbage could be avoided?
I guess i dont really see what part of the tire its rubbing on.
