2017 Raptor Geiser Progressive Springs
MOT26
Las Cruces NM
If you look at the pic you will see the blue line that I drew, above that line is where I had rubbing. You will see the empty space above the line, that is there I cut. I still rub at full left lock (notice the lines above the cut line on the plastic. You might not have this issue with a +17 wheel.
ATXraptor75
Austin, TX
Just got my geisers installed @ TMX on Monday!
Definitely a major improvement in ride quality (more responsive/planted feel) and great leveling the truck out.
+3 Deavers in the back as well.
joey185
I’m surprised yours looks level, I was going to do your route but was adding a drop shackle to keep rear end from being too high.
Jeff-Ohio
Cincinnati
I have the same setup and your truck will have a slight rake with Geiser springs up front and Deaver+3's in the rear. That said, it is not a huge difference and it looks perfect to me.
Kurator
NYC
You'll be nose high not level with geiser, unless you're also planning deavers for the rear. I think eibach is the only spring option to be level but they're also inferior.
What + number is needed on deavers to be same level as front when using geiser springs in the front?
