Umm, the transfer case in behind the transmission which is behind the engine! So probably beside your ass while you are driving.
Not sure what's with the UMMM, but thanks, I will have them look into that.
---------- Post added at 12:22 AM ---------- Previous post was at 12:06 AM ----------
Wow. I would never shift on the fly on this truck or any truck. It will be interesting to see what the dealer finds.
As I originally stated this happened while cruising on the highway, NOT while shifting on the fly or anything like that. I was probably doing 55-60 when this happened.
Are you saying that if you were on the highway and you came up on a snow squall you would pull over, put your Raptor in Park, then shift into 4x4, and then drive off?
Where does it say you cannot shift into 4x4 or from 4x4 back into 4x2 on the fly??
A quick search:
Electronic Shift-On-The-Fly (ESOF) System
The Electronic Shift-On-The-Fly (ESOF) system consists of the following components: •Mode Select Switch (MSS), located on the instrument panel
•TCCM , located near the passenger kick panel
•IWE solenoid, mounted to the cooling fan shroud
•IWEs , located at each front wheel hub
•Transfer case assembly (includes shift motor and synchronization clutch)
Vehicles equipped with an ESOF system allow the operator to choose between 2WD and 2 different 4WD modes. The transfer case is shifted electronically based on the MSS position. Under normal driving conditions, the transfer case is in 2H (4X2), but when desired, the operator may shift into 4H (4X4 HIGH) or 4L (4X4 LOW).
The operator can shift between 2H and 4H at any speed. To shift into 4L, the vehicle must be stopped or moving less than 5 km/h (3 mph) and the transmission in NEUTRAL.
The transfer case is equipped with a synchronization clutch which is located inside the case. The synchronization clutch is used to synchronize the speed of the front driveline with the rear driveline during 2H to 4H shifts.
