2013 stock LEDs headlights on my 2011
Raptor Retrofit
HID Specialist
NY
98infinity
98infinity
Here is the conversion harness if you need a new one, be sure to remove the relay and apply dielectric grease to all the pins before installing, same with the input plug. https://www.theretrofitsource.com/c...150-oem-hid-conversion-2009.html#.V5AxsOT6vnY
This is the pigtail you need if the truck side input was ruined - 2010 FORD F-150 5.4L V8 Headlamp Socket | RockAuto
Hey this has gone to hell again, don't have any lights now. The first link for theretrofitsource.com doesn't work. I'm thinking I need to replace the morimoto box and relay on the back of the box it says number 201407. I'm so confused
NASSTY
ME
Did you check the inline fuse? My inline fuse wasn't blown but kept getting wet and corroded and lost connection. I had to change the fuse and make the fuse holder water tight.
98infinity
Checked everything. I just bought a new harness and everything. Hope I didn't blow the lights.
tomahawk
you need a relay harness or the light will flicker...I had this same problem
