BigJ
- Joined
- Aug 5, 2010
- Posts
- 5,448
- Reaction score
- 1,561
Sure, what measurement do you want? The wall thickness will be a little tricky but I can probably make my calipers work.
My "T-Bird" is on the rack...
SDHQ: when you said "Ford has changed the inside section of the inside frame rail. The material is aprox double the thickness and extends for aprox 12" to the front and rear." were you looking at the bulge there shown in both Josh's and my second pictures? Maybe you just never noticed that bulge before?
The change that I noted is in the inside of the inside frame rail (read above) not the outside of the inside frame rail (like the pictures you are pointing out)
Roger that. Was it a cut plate that was welded in there, or did it actually seem that the frame material itself was thicker in that area?The change that I noted is in the inside of the inside frame rail (read above) not the outside of the inside frame rail (like the pictures you are pointing out)
