Stalled in stop and go traffic today…
2011reptar
okc
check the wiring for fuse 27. actually, just check it all. the dealer did my fuse 27 but didnt. they put a relay in but never completed the wiring so i was still in the fuse 27 slot for power. similiar idle issue as my fuse 27 was partially burnt
I will pull the fuse box and double check everything. I don’t have a fuse in slot 27 any longer, so I guess it wouldn’t be running if it was completely wrong, but doesn’t mean something not loose.
2011reptar
okc
27 should have been relocated to 70.
It has been.
I pulled the hose off the canister purge valve and unplugged it and am getting the faintest bit of vacuum from it. I hate just firing the parts cannon more, but I’ll order one just to see as well.
TomDirt
Hesperia CA
Did the problem start before or after the tune up and were the coils,wires and plugs all replaced? The fuel pump could be it or bad gas . I’d start with checking electrical connections. My mileage is about the same two problems I had were the coils & underbody ground strap .
Do you happen to have a picture of exactly where that is?
MadZeus Darknature
Florida
If my memory is correct it’s passenger side just below the firewall. Not sure if I pulled the skid to get to it . Next time I go under I’ll snap a picture. It looks like the one under the hood same general location and type but longer. Mine was almost gone just a c**t hair left .
TomDirt
Hesperia CA
Is it on the bottom of the frame?
96,611
60,594
Jfelcan
