I wish I liked the gen3
Whitepony04
Whitepony04
oklahoma
Then please enlighten us and show some damn proof. You can look all you want but you won’t find orange stitching anywhere on Ford’s website. So, yeah, you’re color blind.
Here ya go, on the ford build site. Note the orange stitching on the wheel and shifter, orange accents on the dash.
full-race geoff
AZ / NJ
compared to gen 2...
gen 3 engine is improved internally. stronger crankshaft, metal timing chain guides, metal mounting tabs, better lifters/rockers (all can swap over to gen 3)
gen 3 transmission much better than gen 2, and only $1900
gen 3 front suspension better geometry, stronger ball joints, stronger wheel bearings, stronger front axle
gen 3 rear suspension 5 link
shigman
Cypress, TX
You forgot the higher compression ratio on the gen 3 engine…yet is has the exact same power rating…hmmmm
full-race geoff
AZ / NJ
more restrictive oem cats combined with smaller turbos on gen 3 vs higher flowing cats, bigger turbos on gen 2
My GEN2 is paid off and heavily modified. It would cost way too much to recreate it. I will definitely go with a GEN3 if it’s ever totaled.
same same. thats why im swapping gen 3 guts into my aging gen 2!
shigman
Cypress, TX
I mean i guess you missed the goosetuned thread where the gen 3 had a lot more power (especially torque) stock than a stock gen 2.
Badgertits
Ma
The engine is the same- the only changes were in tuning & allowing more TQ into the lower gears, the transmission is the exact same. They changed the compression ration slightly- since you can’t tune a gen3…..that compression ratio bump & the tuning out the TQ mgmt in lower gears means nothing b/c gen2 can run custom tunes….
The advantages in the gen3 are the interior - which is not Raptor specific- & the rear coil suspension setup.
I drove a few Gen3s - the only one that made me think twice was an R, but it’s not realistic for me in terms of budget & mpg.
“Gen3 transmission much better than gen2”- lol, bro it’s exactly the same ahahha
Badgertits
Ma
That’s all from tuning - not mechanical/hardware - again, which can be addressed w/ aftermarket tune. Ford engineers figured the customer base could “handle” the extra TQ down low better w/ coil rear suspension.
I can’t recall- are gen3 trucks recommended for 93 or call for 91+ octane ONLY?
The 3.5HO also has been shown to gain 30whp give or take just running 93 octane vs 87 on an otherwise bone stock truck (some car mag tested & dynoed back to back & the ford 3.5HO was the engine that showed the biggest jump in power running 93 octane)
full-race geoff
AZ / NJ
the gen 3 uses a higher pressure DI system for improved high speed combustion. it also features lifters, rockers and phasers that function as intended. and metal timing chain guides + tensioners that do not flex or break. it is a superior engine.
The engine is the same- the only changes were in tuning & allowing more TQ into the lower gears, the transmission is the exact same. They changed the compression ration slightly- since you can’t tune a gen3…..“Gen3 transmission much better than gen2”- lol, bro it’s exactly the same ahahha
that has not been my experience
