GEN3 Forscan
AARaptor
Katy, TX
I had turned on my marker lights at all times through forscan. How do I revert back to OEM, just on that setting without messing with any of my other changes?
chacquie
DFW, TX
Just following up. The fix was to disable the “adaptive front lighting system” in SCCM.
mleaky
Arizona
Is there anyway to have Pro Power set to Off all the time?
Pro Power should always be off unless you activate it from the dash button or the infotainment screen or plug something in the bed plug and push the green button.
JDMCTR00
Los Angeles,CA
Mine turns on every time I start the truck. I have to manually go in and shut it off(2023).
HORN HIGH ACES
Colorado
anyone know how to change the TPMS sensor thresholds? I've seen some posts on other forums for f250s... id love to change it such that i dont continually have the warning light pop up when my rear tires hit 29 psi or so overnight in the cold
Reviving this question. Has anyone done this??
