Sharpie69
Boston, Ma
91Eunos
Hill country, Tejas
Update… Finally got the 220 circuit run today, albeit just as a temp cord until I can rent a scissor lift to run conduit up top and then finish the drywall.
Regardless, the moment of truth!
Made sure the lift was hitting the jack points, always a little tricky with the shorter wheelbase in my SCAB:
Also confirmed the braces weren’t hitting the running boards, no binding in the lift arms, etc.
A bit close on the passenger side, but gtg:
And we have liftoff!
Can probably go up one more step on the locks, but gonna let it sit like this for now to ensure no leaks, etc. Will drop it back to the ground before hitting the hay tonight though.
Nex
RIP CoronaRaptor
Washington State
Look into a pole jack to help stabilize the truck.
mashtastic
las vegas nv
Adopt me!
91Eunos
Hill country, Tejas
Have two, primarily to support the transmission, but will also look into a couple larger ones
…forgive the mess, still moving crap out of storage and sorting what goes into the attached vs. detached garages!
Zeusmotorworks
Semi-retired, now just a happy grumpy old man!
Northwest shore of Lake Travis
Front got TSW (RPG) top hats with larger Gen 3 12mm studs, bravo valving, viton seals, Schrader valves, and Foutz Shock Tower Support Rings on top.
Rear got the same plus valving adjusted for the Deaver +2 HD‘s.
Digging it thus far…
