Clunking sound on Gen 3 too
LayinWatts69
Las Cruces, NM
well. my new to me CPO Gold 2022 raptor came with the clunking sound. took it to dealer and told me i have to replace the front shock.. it's OUT OF POCKET since it's a wear and tear time. completely BS. Never in my experience had I had a manufacturer tell me shock is a wear and tear item. Acura, Honda, Toyota, they all replaced shock as part of warranty, original or CPO.
Luckily my dealership who sold the truck is reimbursing me for the cost. but its the last time I pay extra a ford CPO. it's leaving a really bad taste in my mouth. I could have bought a non-CPO for significantly less and bought a full coverage aftermarket warranty for A LOT LESS total OTD.
What's the mileage on the truck? And did you print and present them the TSB associated with the clunk?
insangsong78
cali
Just a hair under 40,000 miles. I bought the truck at 39,700 miles I noticed it immediately. What TSB cover the cost of that even when ford declares it as a wear and tear?
taquitos
Seattle
Since it’s out of bumper to bumper there’s no getting it covered unfortunately.
FordTechOne
Detroit
A shock is a wear and tear item regardless of manufacturer. If the CPO warranty doesn’t cover it you can’t expect the manufacturer to make an exception, especially when it was purchased used.
However, I’m sure the dealer made a healthy margin on the sale. They sold it to with the clunk sound, they should be stepping up to cover it at their cost. Keep in mind that the CPO process requires an inspection and test drive; they should have noted that and repaired it at their cost before reselling it. I’d be asking for a copy of the inspection paperwork and requesting to meet with the General Manager.
insangsong78
cali
They cut me a check for replacement shock, but there are number of other issues which I will not repeat on this chat. But ya rear clunk fixed with replacement. I got the old one which I plan on sending to Fox for rebuild. once I have a full set to swap.
Fox is good about sending repair report so I'm hoping they'll tell me what was wrong if anything.
KrashEd
Pennsyltucky
Hi - Just a general, probably oddball, question that I am putting out there since I have the jen tres clunk ('21 37PP). From what I have read, the design changed on these at some point once Ford/Fox realized there was an issue. I can get a hold of two newer rear shocks, cheap, but they are both right rear shocks. Other than the decal being on the wrong side of the reservoir and switching the connector harness mount side, does anyone know if there is a difference side-to-side in the shocks?
taquitos
Seattle
There is no apparent difference in left and right shocks beyond the stickers.
insangsong78
cali
Wonder it any one has taken apart both sides. I could see fronts being different internally if the 4 corner weight is different, but rears I don't see why they would be.
Question remains. Why are they priced differently if so that's different is sticker? Hmmm
taquitos
Seattle
I talked to someone who rebuilds shocks and they told me all the shims measured the same. I have two right front shocks on my truck because of price reasons. No noticeable difference in ride quality or ride height compared to when I had the original shocks on. The only difference I can tell with the fronts is the spring perch comes clocked 180 degrees different, but that’s easy to change.
My theory on price is that their parts portal runs some sort of background task that adjusts price based off volume. Most the ford parts websites appear to be skins of some sort. I doubt a whole lot of shocks are getting ordered online so it wouldn’t take much to skew the price if it’s some automated price adjustment system.
