Window trim rattle/vibration
BoostCreep
SoCal
Update. Took my truck in for 2 rattles and an oil change. The driver B pillar rattle and rear window rattle. I had a TSB for the rear window rattle. Which I printed and gave to them. They acknowledged both rattles. They said the door one, they are working on. But the rear window rattle.... they told me the TSB does not affect my year. Since the TSB says its for 21/22's. The TSB document is dated 2022. I told them, its the same truck 21/22/23 rear window wise and that I wanted it fixed. That I didnt care if they used the TSB or warranty. Just get it fixed.
Then I call ford to ask them to help get this pushed through. The lady said, I should just go down to the dealer and bitch. That they can't do shit. Unreal. They literally told me to go post up at the dealership!
In addition to all of this. Months back, Ford also denied me the heated steering wheel retrofit that my truck matches, year, build date and plant location it was built from. Yet Ford says my vin wasn't affected. Um, I didnt get heated SW. So why wouldn't I be? I didn't get a choice to remove it. They just removed it from my build. Nothing makes any sense.
Needless to say, I am disappointed. Now I'm starting to remember why I left ford in 2018 with my last raptor. Everything is a hassle to get corrected.
What dealer is this? RSM?
The heated wheel only applies to the Lightnings for now. I think Ford messed up in that the letter they sent out wasn’t specific enough, but if you look at the number of affected vehicles, it’s way too little to include Raptors. According to the tech I talked to the Lightnings only require the hvac module, not the SCCM also like our trucks need, so they started with those.
My truck is currently sitting at the dealer and has been all week, and progress has been slow AF.
BIGW0RM
Highest Access Member
Pirate
Yes it was. And unfortunately, my b pillar rattle is already back. At first I thought they replaced a part. But it seems they just played with it. I ended up putting some thin auto grade double sided tape between the rubber window gasket and black outer plastic. I saw someone else did that on a F150 forum so I gave it a try.
Im all done with RSM ford. Those guys just dont seem to want to deal with warranty stuff. Which is a bummer because my lady service rep was actually really cool. Ive tried buying a raptor from them a few times over the years but there ADM games made me walk every time. Going to try tuttle (where I got mine) next. Its where I probably should have gone from the get go too. But Im 5 miles away from RSM so I tried them first.
BoostCreep
SoCal
I think most dealers don’t love doing warranty work unfortunately. I’ve tried to buy a Raptor 3 times from RSM and didn’t work out any of those times for the same reasons. They’re not as bad as others, but don’t really deal either.
Booth9999
Idyllwild
My dealer is amazing. They treat me right and always go the extra mile to make my truck right. Even my 17 Raptor that had the 125000/7yr warrant was well taken care. Find a better dealer for work, they are not all the same just because they say Ford out front. They are all independently owned and very different. Don’t kill ford just because a local dealer sucks. Take the time to find a better dealer.
butts182
Jupiter, FL
Any updates on how to fix the B Pillar rattle? I have it on both driver and passenger now. ‘23 with 14,500 miles
butts182
Jupiter, FL
Not sure. Ive seen some posts on F150 forum saying there is a plastic plate covering on the upper B pillar area that could be the cause. Im just not sure I want to pull mine apart or let the dealer handle it.
Seen here. View attachment 432346
Next time I test my sunroof rattle. I will press down on the seat belt height adjustment button and see if the rattle stops. That button appears to be part of that big plate so well see what happens.
I think this is the source of my b pillar rattle. If I put a decent amount of pressure on the upper seatbelt assembly, it instantly goes away. Well, until I let go.
