AMS Inlet Tubes - broken bracket
XSTNKT
Michigan
So I snapped the drivers side bracket while trying to remove the stock inlet tubes this weekend. This thing is one of the top 5 worst designed brackets I've ever come across. One PLASTIC bracket that mounts to the block with two fasteners on the same plane as each other.... no third fastener in a different location for triangulation... extremely tight bullet style pins on the (two) parts the bracket is tasked with holding. Goodness. It must have been a 1st year intern in the design department at Ford. One-time use product for sure. I hate that cars these days are designed for manufacturing and NOT use.
Anyway <rant off>, it snapped in half. How critical is it to have these inlet tubes held by that bracket? They do move, a little, now. I've epoxied the bracket back together but in my experience, that never holds forever.
Leave it off? Or order a new (sh1tty) part from Ford?
I swear I futzed around with this stupid thing more than the whole front mount intercooler install. Certainly cussed a whole lot more. LolIMG_0720.jpeg
dillard09
College Station, TX and Socal
So I AMS boost tubes and noticed where the pin on the boost tubes goes in the bracket had broke. I had a nice sized hole just open to the atmosphere. Not sure why it broke. So got a replacement boost tube an just removed the bracket all together. No problems so far.
XSTNKT
XSTNKT
Michigan
Thanks. I didn't bust the pin on the AMS tubes, but I DID bust a pin on the passenger side intercooler-side OEM tube. Luckily, the hole didn't go all the way through.... It's so dumb that Ford had to get "all fancy" with these. It could have just been a clamp on a metal bracket. Silly.
