- Joined
- Jan 19, 2015
- Posts
- 272
- Reaction score
- 366
Great info, thanks. I'm tallying up projected costs this morning and it gets pretty ugly pretty fast going with a mid/long travel set up. While it would be cool to have an R that looks as good as my Gen 2 did I have to start considering the fact that this becomes a $170-$180K truck after suspension, bumpers, wheels, tires, lights, etc.This is a great point from @BoostCreep. The FRLV shocks would only work on a 35" truck with the single valve. If you have a 37PP or R, then they won't be compatible with the dual valve setup. Looking back now at your first post, I saw that you mentioned you had a 2024, but didn't realize it was an R.
If you're wanting to go down the rabbit hole of +3 Mid-Travel and keep the dual live valve shocks, then my recommendation would be a Foutz kit as both their mid-travel and their +3 kit will work with stock shocks. For extra height, you can add Eibach or Geiser springs on your factory shocks. And the FMI LCAs will also work with any other components you may want to add like limit straps (highly recommend if you're going to be wheeling hard with aftermarket springs), front bumps, and secondary bypasses. The only thing to keep in mind is that FMI LCA is NOT compatible with the OEM sway bar so you'd either need to run no sway bar or go with the upgraded FMI sway bar that works with their LCAs.
Cool? Yes. Smart? Ehhh, maybe not so much. I can see a significant depreciation hit over the course of a few years ownership, and I'm averse to losing my a$$ on vehicles. Don't mind paying to play, but throwing good money after bad is not very palatable to me. Then I throw in the consideration that this truck most likely won't fit in most parking garage I frequent, and it becomes less appealing to me. Sounds like I should probably consider sticking with some Geisers or Eibach springs for some modest lift height, and then maybe add the Foutz sway bar. I'm liking the sound of increased handling characteristics. Sticking to stock suspension with some level springs will probably help keep that plush factory ride on the road.
