Oil pressure while driving
JasonSTL
St. Louis, MO
I noticed today my oil pressure is between 22 and 23 psi while driving at 55 mph steady cruise. This seems low to me. Does the EB have a different type of oil pump? What’s everyone else’s oil pressure if you have the digital gauges on your trucks?
dboat
Dallas, TX
When was the last time you changed the oil? Are you running synthetic oil? What weight oil are you running?
Sent from my LM-G820 using Tapatalk
GunMonkeyINTL
NC
How are you seeing oil pressure values?
I only have the useless rainbow gauge.
The gauge menu in the ‘19+.
Mine runs between 22 and 65 psi. It doesn’t really matter what speed the tires are turning, it’s the speed the crankshaft is turning.
J
JasonSTL
St. Louis, MO
Thanks for confirming the range on yours. Mine is the same and has 9,000 miles on it. I just felt 22 was a bit low for a newer motor but I don’t think any prior vehicles had a digital oil pressure gauge so maybe that’s normal.
