Reducing body roll with dual front shock setup
t_j
Chicago, IL
So I have the camburg dual shock mount setup with dual Icon shocks, this setup does not have a sway bar. This weekend the chicago group went to the local rallycross event which was awesome, but I had a huge amount of body roll. What should I be changing to combat this? My first thought was to add more preload.
t_j
t_j
Chicago, IL
No option on the camburg dual LCA, I would have to custom make some links and extensions for the shock mount on the lca for the secondary shock.
ntm
Alberta, Canada
Change your valving.
Odd that you have a lot of body roll, the icons have quite a bit of spring rate, are you carrying a bunch of extra weight higher in the truck ?
NorCalRaptor
My dual fronts with the Camburgs are getting installed this weekend. I look forward to any updates.
Thanks
Dan
Hole Shot
Raeford, Nc.
I adapted my stock sway bar links to fit the secondary shock mount hole on my RPG lca's and they bent like tacos the first time off road due to the extreme angle. I was wondering about an rear off road sway bar setup. @svc said they were working on something. I had a lot of issues at snoball with the front end pushing around corners. I am
About to buy a large trailer and would like to run a sway bar. Any suggestions welcome here.
