Passenger Cage, Rear Seat Unlock Mod
Truck has been gone for about a month, got the steering rack replaced under warranty - Cudos to Tuttle Click Ford in Irvine for doing this and replacing the PS High Pressure hose under warranty. After that, we got the truck over to Raceco to finish work on the "Secret Project". Time to let the cat out of the bag. I know this is going to be controversial, but I hope those that think I'm nuts will keep an open mind and read through this before passing judgement.
The reward will be a really cool mod that allows me now to unlock, and lower both rear seat back rests without removing anything else. Ford should look at this and work into future designs.
Passenger Cage:
We have all seen the full cage mods many times, each company does it differently and the results is how much usability as DD do you lose. Can't wait to see the final result that Jarrett did at RPG, so far it is the most usable full cage I have seen. Often the result is that you lose original seats - I like my AC front Seats, lose rear seats and storage underneath. You lose the side and in many cases the front airbags. Anyway, I didn't go that route, what we did was "Bolt in Cage".
What is it:
It primarily is designed to allow the attachment of a four or five point harness system. In addition it also increases the structural integrity of the middle and rear of the cab.
What were the design parameters:
Unfortunately it took several tries, what you are about to see is version 3. In this final version the seats have full travel f/r. The harness bar was raised to just below the seat shoulder. The "B" Pillar was angled in front of the Cab dome light and the rear harness bars were raised to allow the rear seat to move up and down - which was critical for me to get to my tools in the "Tuffy" box below.
It was important to me to not lose the safety feature of the side curtain airbag so what we believe to be enough room was allowed for the top connecting bars of the "B" and "C" pillars.
I asked for some additional attachment points be added so I can strap extra gear down inside the cab.
Even though Jamie came up with a slick "X" cross frame roof setup, I had it removed for passenger safety when riding around town without harnesses or helmets.
To allow for full rear and front seat access
To be stronger and safer than not doing it.
Keep functionality of all existing belts, rear window, dome light, grab handles, coat handles, original seats, Tuffy storage box etc.
![IMG_20130420_115156_355_zps2f596b91.jpg IMG_20130420_115156_355_zps2f596b91.jpg](https://www.fordraptorforum.com/data/attachments/197/197662-6083496c8589477d17f4c71a7424d5bd.jpg)
Here is Jamie’s creation, the two brackets are a little different, this Drivers side has to be drilled and relocated about a ¼” in.
![IMG_20130420_115052_043_zps38a93abf.jpg IMG_20130420_115052_043_zps38a93abf.jpg](https://www.fordraptorforum.com/data/attachments/197/197664-69f30cb5eac9fb94549e39c351a2eb73.jpg)
Here is the passenger side
![IMG_20130420_115029_031_zps8def82bf.jpg IMG_20130420_115029_031_zps8def82bf.jpg](https://www.fordraptorforum.com/data/attachments/197/197666-c1fc8b09fd8cc7da9863ed83bd16fa11.jpg)
Here is the rear “C” pillar mount. There are 4 very large, thick, gusseted steel plates, at all four corners and they each sit on the main cab cross supports. The rear bolts in under the rear seat and seatbelt mounts, probably the strongest section of the entire truck body. The “B” pillar has an additional under cab cross brace that it bolts up to.
![IMG_20130420_115013_456_zpse5ec1b83.jpg IMG_20130420_115013_456_zpse5ec1b83.jpg](https://www.fordraptorforum.com/data/attachments/197/197667-b19ca3c83fb3d2a7ae142b477c02497f.jpg)
Belts fit nicely behind the seat when not in use.
![IMG_20130420_114941_122_zps655d43f7.jpg IMG_20130420_114941_122_zps655d43f7.jpg](https://www.fordraptorforum.com/data/attachments/197/197668-1c8161fe813c6ad33b1587b301cf7332.jpg)
There is now 2 to 3 cubic feet of storage behind the rear seats. Now it does take some strong fingers to release the latch and to secure you need to slam the seat hard while pressing in front of the bracket, but with some practice it is becoming easier and easier. The red arrow is pointed to a 10' coiled recovery sling that is 12” x 3” that is now out of the way.
![c0f38014-9aac-46c7-a7cd-be2dab6b90f1_zpse4358f56.jpg c0f38014-9aac-46c7-a7cd-be2dab6b90f1_zpse4358f56.jpg](https://www.fordraptorforum.com/data/attachments/197/197669-1b8b86434dbbf7f594b4c5c151a6995d.jpg)
Cut the mat to fit around the “B” pillar post
![IMG_20130420_152519_384_zpsb9bb3dbe.jpg IMG_20130420_152519_384_zpsb9bb3dbe.jpg](https://www.fordraptorforum.com/data/attachments/197/197670-2fadf875685695ec36e6522787211329.jpg)
Made some temporary harness holders to keep the belts from sliding off the seat when not on. Harnesses are no fun getting into, I used zip ties before, I think this will work better.
![IMG_20130420_144546_320_zps95ab652c.jpg IMG_20130420_144546_320_zps95ab652c.jpg](https://www.fordraptorforum.com/data/attachments/197/197672-12c3423635498cb748e89fe32fdc50f7.jpg)
It was suggested to simply run the belts between the head rests, I tried that but it constricts the neck.
![IMG_20130420_124115_428_zpsf4b0134c.jpg IMG_20130420_124115_428_zpsf4b0134c.jpg](https://www.fordraptorforum.com/data/attachments/197/197673-77d0b0f9bc4970093a5540ed97119155.jpg)
Needless to say I opted to not go this way.
This pic shows Drivers belt in DD mode, stowed away, holding tool kit behind seat, also I hooked up some bungees so you can see the attach points.
![IMG_20130420_144517_313_zps25acb8c7.jpg IMG_20130420_144517_313_zps25acb8c7.jpg](https://www.fordraptorforum.com/data/attachments/197/197674-c27dfd0fbd455ff615e423a45b1586db.jpg)
For those that have never removed your back seat I posted up some info earlier in this thread, the easiest way to remove the bolts is with air ratchet, 18mm deep socket.
![IMG_20130420_122037_099_zpsf518b0ff.jpg IMG_20130420_122037_099_zpsf518b0ff.jpg](https://www.fordraptorforum.com/data/attachments/197/197675-e5d3b0a7f258b8dbc75efe5e12aec5ff.jpg)
Front seat anchor points are massive eye bolts that go thru hole in bottom of seat frame, the lower belts clip in, the side panel removes easily
![IMG_20130420_120700_738_zps9c2c11ee.jpg IMG_20130420_120700_738_zps9c2c11ee.jpg](https://www.fordraptorforum.com/data/attachments/197/197677-e27cc506392dcf3d326f5248afff4ad5.jpg)
This pic shows how close the rear seat with headrest just kisses the “Oh Shit” handle, er, I mean front shoulder harness tube. Actually that bar was a big hit with my kids and their friends to hold onto when getting into the whoops.
![IMG_20130420_115457_585_zps9264b1e4.jpg IMG_20130420_115457_585_zps9264b1e4.jpg](https://www.fordraptorforum.com/data/attachments/197/197678-f2da8c361b8056be641da19f5ed54cbc.jpg)
