We are very excited about getting this product out to you guys who are looking to upgrade your steering system!
Here are a couple key features of this high end piece.
• Direct bolt in replacement w/ no additional components required (additional fluid supplied)
• CNC machined from 6061 aircraft grade aluminum
• Threaded o-ring cap w/ 12psi pop off valve
• Built in anti-cavitation valve designed to eliminate fluid ariation / foaming
• Increased power steering reservoir fluid volume with increased flow
• High end AN fittings for factory-like seal to OEM power steering lines
• Made in the USA
More info can be found on our website:
Power Steering Solution Ford Raptor Power Steering Reservoir
