Any update on the rack and pics of the tire and other mounts. Will the factory bed extender work inside the bed or only out on the tail gate?
Thanks for being patient
The Factory Bed extender will work inside the bed factory style with full range of motion if you do not use the XRD Anti Bed Spread accessory. Here's the original thread so you can see pictures with the bed extender installed
THE OGT. I will have to also remove the anti bed spreaders if I wish to use it which only takes a few minutes really. Well, if I need to remove the spare, say 10 minutes Nascar style.
This is with two new items, XRD Spare Tire Accessory, and the XRD Anti Bed Spread Accessory
Little Higher
Axe/Shovel on the left and the air system outlet
Hilift on the right rail
Air tank and secondary battery - Will add something else under the tank on the open grate section soon.
All closed up Ninja style
Not sure if I'll make the hilift plates available and the axe/shovel mount are not of my design. Leave this up to the user. Main goal is to mount whatever/however you want to the cage.
