WSI Springs on their way!!
Kanakry
Great Lakes Region
NickPic83
Rockland County NY
So the OG WSI springs are HD and the new WSI springs are SD?
By +2 does that mean 2" taller than stock or about even with stock?
Kanakry
Great Lakes Region
Thats the SD springs with the synergy 1.5" Drop shackle. Truck is on mid perch.
---------- Post added at 01:18 PM ---------- Previous post was at 01:06 PM ----------
Equivalent to top perch with WSI HD springs and 3" drop shackles
T
TAZMAN
North Salem IN
The springs will not be delivered until tomorrow so I am delayed in getting them on. I hope to be able to run 37 inch tires at some point without changing out the front fenders. Gearing will need to be changed also. We will probably put the suspension upgrade on after the 1st of the year. Gotta do a great deal more research before making that jump.
T
TAZMAN
North Salem IN
Springs are here but now I have to figure out what to coat them with. Didn't think about coating until they arrived.
Yukon Joe
Trafford, PA
MPHD (Metal protectant heavy duty)
Freedom Motorports sells it.
You can spray it in afterwards too.
Can you get some spring measurements? Measure from the garage floor to the center of the arch. Compare that measurement to the OEM springs. Then you will know what the height difference really is. (Minus an sagging from the break in period).
Yukon Joe
www.RUNRAPTORRUN.com
T
TAZMAN
North Salem IN
I will get the measurements this weekend when I pull the stock ones out I plan on getting some good pictures so others will have the information to use in the future. I will stay in touch while were going through this and provide information.
