Wow these headlights I want them
Raptor Retrofit
HID Specialist
NY
Any thoughts on these?
yhst-5006790027353_2152_323160240
Not really feeling them but its cool that companies are coming out with some different variations. Maybe we will see a real HID with glass projectors coming out soon.
CineSLR
Roaming Shutterbug
New Orleans, LA
Yup, PShop for sure... They look like they are modeled after the new explorer. If only they actually used the BiXenon projector from the explorer...
Raptor Retrofit
HID Specialist
NY
It must be photo shopped in there. They look like they're pointing down.
There it is, thought they looked a little off. I actually dont think they are that terrible if only the marker light section was blacked out like on the recon's. I'd like to see some actual pics of them on a truck.
BMart
FRF Resident Artist
Perterter Tern
If you buy any aftermarket headlamps or tail lamps, make sure you seal the space between the outer clear cover and the housing itself with silicone. As it's been stated, some of these aftermarket companies aren't the best, and it's common for moisture to get in the inside and destroy it completely.
Back on topic, I would only consider the original ones that Birdman posted. But I know from experience that they probably don't exist. The DOT won't allow lamps that do not have amber reflectors. I've seen this before, companies will photoshop it all blacked out, but when it comes in the mail it looks exactly like SPRSNK's setup. The reflectors in that picture have also been darkened via photo manipulation to give the all black appearance. Don't believe it.
Have Tizzy black your lights out and then use a Rigid 40" as your main!! :shocked:
95,947
59,686
Khoifish
