Wiz's Build
wiz1500
wiz1500
If you ever need to run your cooling fans independent of the truck system here is how . Pull 63 fuse hot wire pin on motor side. Pull main fan relay hot wire pin 5 (turns on fan one) pull low speed relay and ground pin 3 ( fan 2 )..
wiz1500
wiz1500
Ok guy's long time no see..Lets change that and get back into sharing the build...
Lots of things have gone on lately so lets just jump in and as always please feel free to ask questions and I'll do my best to give you an answer..
We took the front end apart to reinforce the the L.C.A. mounts, change the steering rack out and install a new set of 4:88 gears..
Lets start with the mounts.
After you have straightened out your mount box's (if bent) luckily mine were not this is just preventative for me.
Make sure you have a nice clean surface to weld on.
Then tack the plates in.
Next and I highly recommend that you put these in with out the control arm in place as the heat will brake down the rubber bushing in the control arm.. Fixer up some blocks so the box's hold shape when you weld on them..
Then burn them baby's in..
WRCRaptor
Great Lakes
Holly S#%T!! Spring has sprung in MI Wiz is out of hibernation. Good to see you working on the truck. When it's "done" we will have to talk about some KP motorsports work on my truck. W.G.
