Why would oil show up by oil cap or AFE intake?
Dane
Littleton, CO
I'm sorry but I really think this is not a good setup, that drivers side hose is way to close the TB.
It's sucking up oil because it's too close to where the tube narrows creating a venturi affect.
The Driver's side is meant to supply air to the crank case.
And the passenger side is for vacuum.
I would call up AFE and complain or at least get an explanation.
You can always move that one hose closer to the air filter, with some tinkering.
So, you are saying that the AFE stage two CAI is built poorly and everyone who has it (tons of folks here) should be having this problem?
MTF
Celebration, Florida
No not saying that,
but there are more than a few pics showing the same thing on this forum.
My thinking is, this is why people are putting catch cans on both sides.
Dane
Littleton, CO
No not saying that,
Perhaps I'm a bit behind on this issue then, but that sure makes it sound like a design flaw to me. I still don't get how this oil is coming OUT of this breather tube though, but I assume it's also getting sucked into the air intake (probably in tiny amounts).
I've been poking around for more information on this with little success so far, but I probably need to address this.
infinitereality
infinitereality
SLC IR/8
Louisiana
I never added clamps to mine, with building a house and moving I just forgot all about it. I am going to go today to get some hose clamps as well as find my stock oil cap too and see if that helps any.
Dane
Littleton, CO
Mine has had clamps from day one... and you see the result.
I emailed AFE a few days ago with no response yet. I'm betting I won't get one. I'm a bit disappointed.
infinitereality
infinitereality
SLC IR/8
Louisiana
I got mine used so goes to figure. Hell I had to change out the coupler that goes from TB to intake tube when I noticed it was literally falling apart. Piece I have now is a much better one.
Dane
Littleton, CO
Hrm, mine was brand new. Nothing about it appears sketchy at all.
infinitereality
infinitereality
SLC IR/8
Louisiana
I just put my stock oil cap on and installed worm clamps to both hoses on AFE pipe. Cleaned all oil off my valve cover and AFE pipe as well. Will report back any issues.
Oil was on on the bigger tube of the AFE, belive it's the PCV tube.
Dane
Littleton, CO
AFE never responded to me. Not impressed.
