Who is making big power?
jaz13
Do you not understand that a larger engine can be boosted just like the smaller engine? Therefore, the larger engine will always make more power.
We aren't talking about untouched OEM Ford engines anymore once we start talking about making big power- so putting boost to the 6.2L is totally fair game in this discussion. A built and boosted 6.2L will easily do 800+HP at the flywheel. Hell, Roush got 700 HP out of a stroked 7.0L version n/a when it was being developed.
What percentage of G1 owners boosted their 6.2? Do you really believe Ford should design their trucks around that small subset of buyers?
Smaller, turbocharged engines are the new normal and anyone who wants something bigger is going to have to do an engine swap. The upside is a low milage, HO 3.5TT engine will sell for a lot of money so upgrading to a V8 won't be as painful.
As I said in my original post, I'm a typical Raptor owner and I'm glad my engine came dialed in from the factory and doesn't need $10k worth of parts to get the most out of it.
EricM
OHIO
Yes - cross plane crank.
What's different about the pistons?
The rings. Not as much room for them in the vertical stack up of things compared to the 4.6L.
The Coyote engine isn't as tough as Ford has led people to believe, mainly due to the bigger bores/weaker blocks that the Coyotes have vs the stronger mod motor blocks. Ford has taken steps backwards in ultimate strength compared the mod motor to get more displacement and power out of it.
Again with the more displacement and power thing. Ford knows this to be true.
zombiekiller
OG BooBooRunner
New Orleans
CPC is cross plane crank? That's pretty much going to be the next GT500 engine from what I've read. The only downside to the 5.0/5.2 is the pistons can't be made as stout as the older 4.6 mod motor engines, which does matter when you are going for really big numbers.
anyone that is putting more than 600 HP into an offroad oriented Prerunner is wasting their time and money.
Hell, Go look at what the TT folks are prerunning in. Generally, it is a 600-650 hp MAX engine. The rest of the build is all suspension and safety.
I'm making over 700 crank HP on a FPC 5.2 voodoo motor.
and SC'ed CPC 5.2 will be kind of bored making 550-600 to the wheels and will have TONS of room to push higher. I'd be more worried about the rest of the driveline holding the power.
I'd also love to understand what the "big power" bar actually is for the purposes of this debate.
How much speed you can carry ( i.e. suspension functionality) is far more important than how much horsepower you make.
---------- Post added at 01:42 PM ---------- Previous post was at 01:39 PM ----------
I beg to differ completely.
The 5.2 is much much different than the coyote from a block and heads perspective. It is reinforced and the jackets are all different.
hell, the return that I got from port/polish/flow on my voodoo heads totally wasn't worth what it cost to have it done.
EricM
OHIO
Blah blah- dude you have a serious lack of reading comprehension. What don't you understand here? We are talking about big power. We aren't talking about what 95% of people do, or what the typical guy does, or what the OEMs are doing- we are talking bout making big power in a Raptor. Your truck came with about 10% more power than the 6.2L engine had- don't act like you got a ******* rocket under your hood compared to the outgoing engine.
---------- Post added at 02:54 PM ---------- Previous post was at 02:44 PM ----------
Big power, I'd say is 800+ at the crank as of now. Ten years from now, probably 1000+. If I can handle 700 HP in a little 3400 lb car, I'm sure I could handle that much power in a 6000 lb truck.
As for the Mustang engines, I know for a fact all Coyote engines have weaker blocks than the 4.6L in my 2003 Mustang. But please, go ahead and differ all you want- you don't have to beg.
Your Voodoo engine has great heads and intake and all that, fancy sounding FPC crank, yea, but if you want to make 1500 HP+ to drag race it, you start with a 4.6L based mod motor block and not a Coyote or Voodoo block. Actually right now there is an aftermarket block available that is better than any OEM Ford block, but when it comes to OEM stuff, the 05-08 WAP/Aluminator block is the strongest block ever put in any Ford V8 gas engine ever made, period.
Then as as I said, if you look at the way the ring packages were manipulated to create the 5.0L engine from the 4.6L engine, the 5.0L has less amterial to work with, therefore the ultimate power capability of the piston design is weaker. Again- fell free to differ with any tech to back it up other than you spent a bunch of money on your engine and it's fast.
All of what I'm saying only matters when you get into the 800/900+ HP range. Anything less than that is not really an issue for any of the 4.6/5.0/5.2 castings.
zombiekiller
OG BooBooRunner
New Orleans
I'll say this much. Hindsight is always 20/20. Instead of buying an '18. I should have bought a '14 and did the fiberglass conversion.
the Ecoboost is tuned too close to its absolute potential for it to have the same level of longevity that the 6.2 has.
I'll never get perfection out of any vehicle that i buy off the lot, and I'll use this logic to make me feel better about modifying everything that I own, new or old. :win:
---------- Post added at 02:22 PM ---------- Previous post was at 01:56 PM ----------
you won't catch me denying that the 5.2 block doesn't need a little bit of help. I ended up having my block sleeved by MMR. This was far more cost-effective than dropping 28K for a tall deck, 3500HP capable variant. Net/net, I feel that without iron sleeving, a 5.2 block will hold 900 or so HP. Sleeved, I feel like it will hold up to 1500-1600. ( in either scenario, you're talking racecar levels of maintenance.)
top ring clearance is the biggest pain in the ass problem on the motors. From the factory Ford sets them up "loose" and the ring/piston design is similar to Kieth black stuff where the top ring runs hotter and expands to maximize reflectivity and thus power. When trying to change ANYTHING to wick the thing up, you usually end up with either too much or too little ring clearance.
We had 4 different sets of rings on my motor before we found the sweet spot. (it eventually came down to ring material and its expansion properties and no so much the gap.) we opted to start with too much clearance so that there was not a risk of borking the pistons or cylinders, as I was unwilling to re-spend on a block, sleeving or pistons in order to support my engine builder's "testing".
However, If I ever need more than 600 HP in a prerunner, I'm doing something wrong.
If my ecoboost takes another shit and Ford decides to not cover it under warranty, I plan to go with a 5.0 or 5.2 due to the transmission compatibility. If a bellhousing is out for the 10 speed that gives me other options at that point, I will absolutely consider an alternative.
I think running a 5.0 or 5.2 for my scenario ( being that I'd like to be somewhere around 550/550 if I had my druthers) facilitates far more "performance overhead" than any ecoboost and I'd expect a lot more longevity.
When all is said and done, i guess I'll still come back to " WTF do you need "big powah" in a raptor anyway?" and that point is in no way, shape or form directed at you.
TXRaptor
Not that this never happens on this forum, but I think the discussion went way past the OP question or intent of the thread... :biggrin:
Continue on ...
jaz13
You're the one with reading comprehension problems. I responded to a post that claimed all the big modded HO 3.5TT's were blowing up. And my comment was that the engine was pretty much dialed in from the factory and that means it doesn't have much of overhead for exploitation. And for the majority of Raptor owner's that's actually a good thing because they are not dragging around a lot of dead weight.
And yes, you are right. HO 3.5TT puts out 10% more power while weighing 100lbs less and getting 20% better MPG. It really is the best tool for the job.
Bhollier
I can say this from someone who is running big power in their Raptor, it isn't just the block you have to worry about. Start with all gaskets, rods, linkage, lubrication system, cooling system, fuel supply, ignition system, and basically the rest of the engine. Then you can start laying down bigger HP numbers in the 3.5. I have mine turned down on the tune so I can drive it daily and it puts out just over 600hp. I can turn it up and have a beast over 700hp with everything I have in it. Would be rebuilding it often if I ran all out daily.
For everyone saying what is the point, simple, Because I can! I also had a pro race team pull the engine and all components, rework and rebuild them to do what I wanted to have under the hood. Now if I can find a dyno where my truck will fit I can lay down the numbers as the engine was out when the tune was done. And like several others have found out when they see my build sheet, don't ask about the cost just sign the check.
Last for those that think it is a street queen, it sees it's time offroad running oil lease roads. It sees mud when needed. The rest of the time it is clean.
G
gijosh28
Well, that escalated quickly.
Not to further the arguing and banter ruining another thread on this forum, but the replacement (mathematically) for displacement is RPM. Sport bikes make hundreds of horsepower per liter.
So, anyone making big power? What have you done and what did you gain? One dude listed what he had done and what he thought he was making. Anyone get any dyno tuning instead of a canned tune?
I keep reading people who claim to make a lot of power, but nothing specific. Which trucks have blown up? What caused it? Bad rods/crank/piston? Not enough fuel system? Limit of the block? Oil starvation? Anything more than hearsay?
