What did you do to your Raptor today? (Gen2)
Danactive
I'm Back!
Syracuse, NY
25k on the clock so barely broken in ;) gear oil looked pretty decent actually as I don't always take it easy on ol' girl. It was definitely dark though, glad I changed it out.
So funny enough, I wanted to support my local Ford dealer, order it through them, and then use Fordpass points to pay for a large chunk of it. After waiting for 7 weeks with no communication from them, I got frustrated and ordered it through a large online retailer. This is the first mod I've done that doesn't support a vendor here so I'll leave it at that.
Spicer is the non-Ford branded one.
Diff cover was $250, LL gasket was $25, and AMSOIL was $56.
thanks for the info... how come you didnt go with the spicer one? i heard its like $100 cheaper?
Terp
Fort Collins, CO
Finally got my recovery boards mounted to the Retrax canister and the correct plate for the ProEagle. Last of the bed goodies for now until I figure out which air compressor I want to go with.
Braaaaptor
Starbucks Enthusiast
The drive-thru
Changed out the spark plugs today. 25k on the clock, tuned since 10k miles, figured its a cheap way to keep the truck running fresh. First start up sounded way cleaner and easier than it had been starting previously.
Todd Turbo S
Nor Cal
I purchased this carbon fiber center from California Pony Cars. Overall really good quality and the weave matches very close to the OEM carbon fiber shift knob, however, I broke a center tab when I had to remove it after installing it because I didn’t realize I needed to remove the chrome bevel trim on the original one. One of the tabs broke off, ended up fixing it with epoxy then fiber glass. I’m sure if I ever have to remove it again the tab will break again. But looks good.
Donovan
DC
I purchased this carbon fiber center from California Pony Cars. Overall really good quality and the weave matches very close to the OEM carbon fiber shift knob, however, I broke a center tab when I had to remove it after installing it because I didn’t realize I needed to remove the chrome basil trim on the original one. One of the tabs broke off, ended up fixing it with epoxy then fiber glass. I’m sure if I ever have to remove it again the tab will break again. But looks good.
Clean, but how does that carbon compare to the carbon in your Turbo S?
Todd Turbo S
Nor Cal
Much different. The Turbo CF has a bit of a green hue to it, but it’s over 20 years old…
