What did you do to your Raptor today? (Gen2)
Rednose
Dubai
Following up on my cousins Raptor exhaust, rear bumper and Dp build he is currently in the military and I just got those videos from the builder no info yet on the material and sizes yet ill be visiting him this weekend.
nikhsub1
Los Angeles
You really don't want to ever combine the exhaust from each turbo. X pipes, Y pipes, H pipes they are all garbage for turbo applications. Where the 2 pipes go to one then go back to two, huge restriction and will be a detriment to power. I'd have it redone.
Rednose
Dubai
You might be right but here is my take and specially on the power this truck had an engine failure pre having this setup installed after the the engine got replaced the truck went for Dp,Ic and a exhaust and the result were amazing the truck was super fast comparing to my truck but I am not sure thought is it of the new setup or the new engine they both will comprise in a way. I hated my truck that day.
zombiekiller
OG BooBooRunner
New Orleans
uh, all of the exhausts go from two pipes to merging at the resonator, to splitting again. ( the EcoBoost likes a little bit of backpressure and actually makes a little more power with it.
however, I'm not clear on why you'd merge the pipes over and over again.
Rednose
Dubai
(As per the builder) In turbo charge engines the gas exists directly to the turbine to rotate the wheels and exists out again any back pressure from the exhuast will slow the spooling of the turbine wheel and that less power and more heat and accordingly it’s more restriction to the engine because the engine is creating the gas.
Maybe back pressure is needed in naturally aspirated engines. But not turbo engines.
zombiekiller
OG BooBooRunner
New Orleans
normally, that is true. On these specific motors, they make more power with 2.75" exhaust vs 3" exhaust. ( roughly 10-15hp) They actually like a little backpressure.
xrocket21
Maine
This is correct. A turbine is a turbine. the raptor doesn't have some magical special turbine.
The best exhaust for a turbo car is nothing after the turbine housing.
Rednose
Dubai
Got you and what your saying is true I have read it somewhere but the power delivery on this truck is amazing after the exhaust and intercooler based on tube and fin the one o have now is a big no for me as I got overheating again and it blocking my radiator.
Rednose
Dubai
The truck performance is great but I’ll have to test more and give you feedback or it.
