What did you do to your Raptor today? (Gen2)
coachhomer
Installed Icon UCA and Fox 3.0 on drivers side. Took me about 4 hours in total. ceb5a92437673dacf2416f91cef43557.jpg
Sorry should be in Gen 1 section. Missed that.
MJK
Busy weekend. Installed new speakers, S1 Bed Light kit, & the plastic fender liner extenders/fog light protection kit.
This is slick. Send me the parts of this S1 setup. I can see the built right gear. I have the S1 and harness for the upfitter
RAPTOHYBRID
Florida
Had my first oil change at 2,746 miles at a dealer. It took about 50 minutes for "The Works" service which includes the oil change, filter, and tire rotation along with checks of various components.
Tire rotation at 2746 miles??? any particular reason?
Gerald
Houston
Only that it was part of the overall service being provided. Just easier to have them do it while they had the truck up on the lift. Otherwise I would have to do it at 5000 miles myself. In my younger days, no issues. But now a days, I'll take advantage when I can.
Heeblet
Pls post link to parts? Looks great. I have a spare S2 sport will be using for similar setup.
hj_s14
CA
Had a busy weekend.
Sat = KC fog triple light kit with bezel installed
Sun = Plastic fender liner extenders to cover the fog lights. Then Husky rear wheel well liners.
The rear wheel liner was a pain in the ass to install. Due to the liner needs to be between the fender and the OEM flare, it'll cause the 2 bottom holes on the flare to not lined up correctly with the hole so it was like "wrestling" around with them.
Also the fender liner was touching to the wire of the shocks, so I had to use a plastic hose to cover the wire (in case any rubbing and cut)
clark98ut
Liberty Hill, TX
You'll need the following...
Built Right panel (the kit I got from 4x4truckleds.com comes with the small one, but either will work)
BD light
BD upfitter harness
BD 10’ extension (you'll either need 2 of these or you'll need to splice about 4' of wire onto one of the harnesses...I did it on the one coming off the back of the light)
67 Designs carbon fiber arm
2x ball mounts from Tackform (Tripod Adapter | 1/4"-20 Hole | 20mm Ball Connection | Enduro Series)
2x SS 1/4-20 x 3/4” bolts and a couple of lock washers
