What did you do to your Raptor today? (Gen2)
BBR
Race City NC
Definitely feel the difference going thru a corner. Not as much roll. Not as sloppy.
Rattle at slow speed from the end links.
Thanks.
I’m at 111k and these are the only front end pieces that haven’t been touched. No rattle but feels like front end could be tighter.
ThePaintPirate
SE Iowa
Installed the Cobb tuner over the weekend. Even though the truck was on a 15amp charger and lights off, after the flash was complete, on the initial start up the truck didn't want to start as if the battery was really low, negative was connected after the BMS sensor so the computer should've seen that it was charging. Second attempt, the truck started like normal and has started just fine ever since. Not sure what to make of that.
So far just the buttery smooth shifting makes it worth the price, but an additional plus is that the cam phaser rattle has all but disappeared. Before and after the dealer ECM update it sounded like a diesel for 0.5 seconds on start up. Now I can't hear anything.
Space Ghost
FL
Cooper at3 37s on
Feels a bit better than the 35s and just a slight rub on the frs reservoirs up front. Dont seem to notice the extra weight.
Gotta adjust the tire size in forscan, but balanced super well.
Also had mine stacked to some nittos or w/e in the same spec
No wonder you get such differing results on 37 threads
View attachment 473489View attachment 473490View attachment 473487View attachment 473488
filled her up, not bad range with 37s on
Added some graphics to the tail lights
