What did you do to your Raptor today? (Gen2)
Sig Fanboy
WV
When I got mine it didn't fit right, so I called. They asked for pictures. It had "Ford performance " cut into it. Was told that it was a prototype and they had been looking for it, would I please send it back. I did the right thing and did so. Damn it!!
The bracket going over the top was wrong but bottom piece was correct and that is the part that had the "Ford Performance ".
Did you install a Spicer or FP diff cover as well? If so, did the “ spacers” look like small aluminum flat washers? I was worried that the 6 bolts that attach the skid wouldn’t compress against the diff cover sufficiently to seal again the rear end housing, but it did eventually pull tight. I think the rear end profile on the pinion side of a Gen 1 must be slightly different than the pinion side profile of a Gen 2&3.
Old-Raptor-guy
USA
Spicer cover, yea basically washers. I put all the bolts in, including front bracket over the top of pinion. Tightened the back cover bolts first and then Tightened the front bracket.
Braaaaptor
Starbucks Enthusiast
The drive-thru
@smurfslayer What bumper mount is that? I'm considering some LP6s in the future but mounting them to the stock bumper seems a pain. The SPV mount is no longer in production unless you get them to custom make it.
N-Fab
Be careful about putting too many lights toward the center. The bar takes up just a little bit of camera space and lights close to the front camera will not help that.
