nowplaying
Gilroy, CA
Custom Method caps faded so I had them powder coated again. I think it matches better than the original color.
Not sure if I want to paint the outline of the logo or just leave it all black.
All black seems to go with my blackout theme.
Buckeyesvtraptor
Columbus, oh
Started with the install of the Boatec fenders and ADD liners. Still got a long way to go.....
So far, it seems that the fit and finish of these fenders is spot on. The door gaps and the hood gaps are perfect. The liners are going to require some tweaking to fit around the Icon reservoirs, but pretty minor stuff. I still have to trim the valence a little. Once all the test fitting is complete, I'll Raptor Liner the inside of the fenders and both sides of the inner liners. Then it's off to paint!!! Stay tuned......
Looks great so far. Jealous
Deleted member 12951
Guest
Torqued the rear end and marked it. Glad I did, was surprises how much there was to torque on the u-bolts.
Guest
Changed out the rear brake lines with +4" SS ones from @RSiWORKS. Just from the frame to the axle to allow more droop for now. Will do the fronts at a later time. Used zip ties to replace what was lost with the factory setup to keep the lines together. It all moves freely. Brake line frame bracket is now screwed back into frame instead of held onto the electrical harness to the rear.
More things to do, getting it prepped for RTF this week.
Bulletnjm
New Jersey
Just building the light setup. Making the KC lights and the bar they are on fully removable so that the thieves cant get to them.
Here is the wiring harness I built for the lights. Adding a quick disconnect for removal of the bar mount.
Woah, some how i missed this. That ADD Rack looks really good can't wait to see it with the lights mounted up!
