Yukon Joe
Trafford, PA
Installed whelen micro pioneers to compliment my baja designs squadrons. :rockit: I'll post pics later.
Sweet... wanna see pics. Where did you get them.
Yukon Joe
---------- Post added at 09:11 PM ---------- Previous post was at 09:11 PM ----------
Replaced this:
Replaced stock fox with these
Thanks to WSI and his helper Whtrapta!
-Greg
Hope you bought them a beer.
Yukon Joe
Kmandoske
Bartlett, IL
Today I hit the mid perch. Only saw the tread on the forum for directions and took after it with my buddy Phil this morning. the first side (Drivers side) toook about 2 hours. Had difficulty getting the space between the bottom of the compressed spring and the stop. After a little wiggling and learning I was able to get it done. The second side was cake, I knew what tricks and I had it done in under 20 minutes. I think I spent more time jacking it up and taking the tire off and on. The lesson I learned was to compress the spring as much as you can with the weight of the truck, after the compressors are drawn down lower the a-arm jack and move the weight of the truck to a jack stand. This is the real lesson...when you think the a-arm is as low as it can go use a pry bar from the spring to the a-arm and it will go down even lower. (held me up for 35 minutes) that was enough space to slide up the plastic, remove the alan set screw and slide up the snap ring. PM me if you have any questions or need help in the chicago area.
SterlingE55
Houston
Yukon Joe
Yukon Joe
I got them from an online retailer. (dont want to step on any sponsors toes) They were $250 online. It's the first retailer that comes up in a google search. I had to wait a month while they were on backorder. I mounted them behind the grill so their output is a little muted.
