puddle hunter
Stockton, CA
I put in the amber/yellow lenses on my @SideTracked Offroad Tracker T6 pods (18w spot). Very easy to swap, and the rubber gasket inside was nice to see. I've heard horror stories of ebay brands, just gooping silicon into the seams. While working on those, I rechecked all the mounting bolts for the rest of my lights, and re-aimed my hood lights.
Stang
What does this do?
Catches the oil blowby off the crankcase via the PCV system which would otherwise be redirected back into the intake. Oil mixing with the air/fuel effectively lowers your octane rating robbing performance. Especially important if you run a tune.
t_j
Chicago, IL
Well today was a 1 step forward 2 steps back kinda day. At lunch I went and installed the camburg steering rack spacers, on of which I machined yesterday. After that I pulled the IWE's and bearings from the knuckles, and while doing so found that I had a failed IWE as the gear split away from the rubber diaphragm also found a couple of cracks in the welds for the gusset set that need repairing. Once I get the knuckles back from the media blasting shop I will fix the welds and drop them off for powdercoat. Pictures of the failures can be found here: More broken shit - Album on Imgur
This evening I cleaned up the old crummy paint and rust on the LCA mount doubler plates and prep'd them for some fresh paint, I also removed the stock headlights in preparation for my retrofits going in. I also ordered some stock to machine some new spacers for my Icon 3.0"s that should fit a little better with the camburg LCAs, they need to be a little thinner, and the icon ones are a little messed up after removing them from the LCAs.
Members online
96,423
60,352
luis2017
