How did the install go? Do you have any pictures of it? I was wondering where it mounts? Thank you.
I am the WORST with pictures as I never seem to stop and take them during the install process. I will try to get under the truck tonight and take a couple.
The install kit is good. I would say a level 3 out of 6 being the most difficult.
Some interpretation and minor skill is required. A general knowledge of your truck is a must.
Compressor and tank mount to a really nice bracket which is bolted to the passenger side frame. Very secure with big 3/4" bolts that pass through existing holes on the frame rail.
Wire harness is all pre made to the relay so it is just a matter of routing the wires and air lines.
The 230 horns are all pre assembled on a bracket that holds the horns, solenoid, and air manifold.
That mates to a really clever bracket that fits between the frame rails in front and above the rear axle in a empty space under the bed. You cant see the location until you lower your factory spare tire. Horns face forward.
Once buttoned up, you cant see the horns at all unless you lay on your back under the front side of the bed.
As for being a good air source, I plan to alter the design by relocating coupler that is mounted on the tank to a location TBD on the bed or cab of the truck. That way I am not fighting dirt and contaminates that get in the coupler while under the truck. It will also be an easier location to plug in an air hose for tools or tire inflation.
Hope this helps paint the picture I neglected to take while working on it.
