The Car Stereo Company
here, on frf
This really is not a hard install to do, just a little time consuming. You will need an impact with 12" extension and wobble socket to pull the seat bolts out, then a couple of smaller sockets for some of the interior panels.
1) Remove all seats
2) Remove center console
3) Remove trim panels on door pillars
4) Pull the rear sound deadening
5) Roll the carpet to the front of the truck
6) Apply sound deadening to all surfaces making sure to cut holes for the things you have to bolt back down.
7) Reverse steps 5-1
Important note: Don't do this if its going to rain and you're working outside, I should really have checked the weather forecast before starting mine.
you are almost there. you should pull the rear seat out and then the carpet comes out. it makes it easier to work when it is completely out.
t_j
Chicago, IL
I had all the seats out of mine when I did it, just didn't want to risk pulling the carpet all the way out. Anyway point 1 was remove all seats :p
here, on frf
......i knew that........ "all seats" "front seats" sound the same......
for those of you interested, there is a special on focal sound deadening for another week. it is still a bit more expensive product compared to the others out there, but it is a lot better since it has an additional layer of closed cell foam.
SilentShooter
Siesta Key, FL
Where do we order it? I have been wanting to do some on my truck. What do you recommend as far as what is needed to do the floor and back wall as well as door panels.
justuspost
Portland OR
How much? From where?
beachz
Monument, CO
...yesterday...
Rotated the tires and changed the front pads. They were squealing and I found that they were cracked when I pulled them off. WTF?
jcl48
South Florida
Spent all day today with a buddy, Replacing the Factory Radiator with a CBR one from SDHQ; also installed the RPG Power Steering Reservoir and SDHQ Power Steering Cooler. Very happy with all the great quality products we Installed today. Tomorrow will be Test Day on a regular Daily Drive. Plans for the weekend are hit up some Off-Road Trails through the Mountains.
---------- Post added at 04:13 AM ---------- Previous post was at 04:09 AM ----------
Next Parts to install this week or next are: Derale Transmission Cooler, AFE Transmission Pan.
puddle hunter
Stockton, CA
Now that it's CARB legal, I installed the AFE Stage 2 intake with the dry filter. I was actually surprised that 4wheelparts had one in stock.
