Deleted member 12951
Guest
Finally the SVC black skid plate arrived today. The moment I got home, installed it.
Will use this when doing raptor runs.
TheJoker
N. E. Massachusetts
Here's a few pictures, when I did mine, from an old post, First picture factory opening, then modded. If you look on wiz1500 build, you will see he added a few more openings.
Joe's @J DAMAGE thread was my starting point. I don't think I went as big on my openings though. After I made the cuts, I cleaned up the edges with a file and used a black permanent marker to hide the white fiberglass (Tuxedo Black Raptor). Will post pics
J DAMAGE
NJ
I got lucky, being my truck is silver, you couldn't really tell being the material is gray, also that's what makes this forum great, you went off my write up, I went off wiz1500 write up, its great having members so willing to pass on and or help others out, and the love for tinkering doesn't hurt.
t_j
Chicago, IL
Finished my radio instal (Icom ID-880H)l:
* Removed configuration diodes to open up full TX range
* Radio installed behind rear passenger seat
* Custom mount plate for head unit on my tablet mount
* Custom remote speaker, need to rebuild the box this was a 15 minute kludge using makercase.com that I laser cut from 1/8th in ply, going to make a mount that holds it on the head rest of the drivers seat.
* Custom machined NMO mount in the drivers side rear bed stake pocket
* All wiring in hidden in the loom or under the carpet
Todo:
* Make a clamp for the mic socket to old it on the base of the tablet mount
* Re make the speaker box
* Run the speaker wiring under the carpet
Pictures will be posted in the radio install thread.
* Drilled and mounted the lower pivot plates for the SDHQ bed supports. Tomorrow morning I need to go buy 2 bolts (missing) to finish up the install.
